exchangeable parts
Old 09-23-2011, 02:22 PM
CitrusTheDragon's Avatar
exchangeable parts
How exchangeable are the parts from 85-88 22re and 89-95 22re? I'm doing an engine rebuild and I am having a really hard time find 86-88 parts, and I know the upper intake mod is a good one to do if you can find one cheap.
Old 09-23-2011, 02:37 PM
yotarover's Avatar
what parts do you need ?
Old 09-23-2011, 03:00 PM
I am thinking exhaust, intake upper and lower, and fuel injectors. I'm most likely buying a new head and cam from engnbldr. I just have a lot of older parts with a lot of miles and was thinking if I saw something cheap I would get it the next time I am at the yards
Old 09-23-2011, 03:04 PM
yotarover's Avatar
check ur pm's
Old 10-01-2011, 11:57 AM
Ok it's been about a week and no luck on getting any further into knowing what I will need to make my swap. I have a great deal on a 93 upper and lower intake with venom injectors from what I can tell these things a will not fit the wiring on my 86 4runner but they will work with my new RV head I am going to be installing. So my question is can I swap some parts off another 22re to make the injectors work? Any help would be great even if I am doing a google search wrong or can find the info by reading a sit I can't seem to find. Also pics would help me a lot too
Old 10-01-2011, 06:54 PM
peow130's Avatar
Best way to check is to look up part numbers.. Same part numbers = same parts, different = not the same, but possibly interchangeable
Old 10-02-2011, 07:47 AM
I know they part numbers are different... yota changed a lot of parts between 86-88 and 89-95... I was curious if I could just swap in a few extra parts from the late model
Old 10-02-2011, 08:45 AM
INFINITY's Avatar
not the best for parts comparison but O'reilly's website has a feture on its website that once you enter the vehicle and select a part you can click the compatibility tab under the part. might help...
Old 10-02-2011, 02:20 PM
91muddog's Avatar
get the connectors for the newer style injectors and solder/heatshrink them into your harness!!
cheap, easy and 100% reliable if you do it right!
woouldnt be very hard
Old 10-02-2011, 09:41 PM
That's what I was thinking of doing
Old 10-04-2011, 10:22 AM
Do you know of anyone that has done this mod or have you done it your self?
Old 10-04-2011, 10:27 AM
Hey can someone do me a huge favor and take a picture of their injectors connectors and wires? I need multiple years if any one can, thanks
05-20-2016 10:27 AM
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
Fundy Rider
07-16-2015 01:35 AM
akaphilly
07-09-2015 02:34 PM
Quick Reply: exchangeable parts
