Ever see hub breakage like this?
Old 11-24-2009, 10:28 PM
jimep's Avatar
my buddy's got a 91 SAS'D W/34'S, stock re, w/ dual cases. Out wheeling one night and he says his hub just fell off! Found all 6 bolts and 2 dowel pins sheared off. I thought there was other things that would have broke first. Ie stock birfs or internals (hub gear possibly) but this just seems a little out there. Any body else ever see something like this? Think catching it on a rock might do it, or possibly just sheared off from torque?
Old 11-24-2009, 10:34 PM
toyospearo's Avatar
GOOD GOD!
Nope, I have never seen anything like that.
Old 11-24-2009, 10:35 PM
91_TOYOTA_4x4's Avatar
nope havent seen that before lol maybe something wasn't put together right and it put a ton of stress on it?? weird
Old 11-24-2009, 11:36 PM
ESQ
ESQ's Avatar
Might be due to overtorquing all the bolts. Combine that with the shear of an impact and/or too much torque to the wheels and there you go.
Did you check the other side?
Old 11-25-2009, 12:49 AM
drew303's Avatar
WHAT ESQ SAID!
Over-torqued nuts. Thats how you sheer wheel studs (and direct impact).
I to have never seen this but overtorquing seems to be the only plausible explanation for this. Thats the only thing that could really weaken them that i can think of... or under torqued?
Old 11-25-2009, 01:16 AM
Just Learning's Avatar
was grease used- then a impact???
Old 11-25-2009, 06:22 AM
waskillywabbit's Avatar
My bet is he did not use cone washers or never torqued them properly, as in too loose.
Regardless it was probably caused by human error instead of a mechanical failure.
Last sfa I bought had flat washers and no cone washers on the manual hubs.
Old 11-25-2009, 06:43 AM
RustBucket's Avatar
If the cone washers were removed, wouldn't the base of the cone taper act like a knife to the studs?
Old 11-25-2009, 07:35 AM
fillsrunner4's Avatar
Ive seen it
Seen the six bolts and 2 pins shear off a few times. Be sure you have all your bolts tight before you go out wheelin next time and I mean tight to there specs. Be glad it wasnt the birf or other internals. The bolts and pins are easy to fix
Old 11-25-2009, 12:08 PM
jimep's Avatar
Not sure how he installed it but i'm fairly certain he used the cone washers- overtorqe is a possibility w/him but I usually just use a 1/4 inch drive for those little bolts. luckily we got a few axles for parts and just replaced the whole spindle assembly with new used cones.
Old 11-25-2009, 02:26 PM
To prevent this:
Properly torque the hub studs
Upgrade the hub studs to ARP
Upgrade to the six dowel mod
Old 11-25-2009, 02:44 PM
and some drive flanges well ok maybe not for the DD rigs
Old 11-25-2009, 02:45 PM
and some drive flanges well ok maybe not for the DD rigs. get some longs too cause the next thing is the birfs
Old 11-26-2009, 03:34 AM
jimep's Avatar
she won't let me get bobby longs at least not yet. but they're coming and she's not gonna know when. Just don't tell her I said that. I've had my share of broken birfs.
ladybugRC
458
08-21-2020 10:41 AM
G-off
12-29-2015 12:44 PM
AaronM
12
11-04-2015 04:06 PM
stanz
10-30-2015 10:33 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Ever see hub breakage like this?
