engine wont start!!!!
i just replaced the head and the timing chain on a '92 22re and put it back together and now it wont start, it has gas the timing is set and it wants to start but it wont, any advice would be great...
how many times do i have to say the timing is fine and set up where it supposed to be, and for grabbing the wire im not stupid enough to grab hold of one
in cyl 2, is there spark? what kind of compression you getting? spark plug wire okay? spark plug okay? is it throwing a code?
bro, calm down, being a jerk to people who are tryin to help you is going to get you nowhere. he said check the timing because a LOT of people set it 180 degrees off. extremely easy to. so dont get your panties up in a twist. and he was KIDDING about grabbing a wire and cranking. so come on dude, cool it.
Check the plug, check the wires and make sure you have them right and the connections are good. Check the compression.
It may not hurt to play with the timing a little bit.
Check the valves.
Did you replace the head due to a warped beyond machining or cracked head? Where'd you get the replacement from? Could explain some things.
Sounds like you're not getting spark to that cylinder, but it could be fuel. Check the injectors?
I think if I continue to hear people say calm down to someone else on the internet I'm gonna go around curb stomping people.
Check the valves.
Did you replace the head due a warped beyond machining or cracked head? Where'd you get the replacement from? Could explain some things.
Check the valves.
Kaydon to the comedic rescue!
Ever had an irish carbomb? guiness stout in a glass, double-shot glass with 1 shot Jameson and one shot Bailey's. Carefully drop the double into the guiness and drink quickly. 3-4 and you'll be arssed out.
