Engine Cut Off after a hard stop!
I would also check the brake booster vacuum lines. On our subaru, I found no issues with a vacuum leak, but the problem seems to be a selanoid inside the transmission that's not going into neutral when coming to an abrupt stop.
Start the truck and let it idle.....stab the brakes several times and see if the engine stumbles or dies.....that will test to see if the booster is leaking.
Sounds like a wire shorting against something or your COR (circuit open relay) relay is not making good contact in the socket or is going bad. Those relays can be a problem since our trucks are getting old. Sounds like you are in for a bitch of a time finding that one.
If that doesn't fix it I would be looking to the AFM. It controls your fuel pump and air/fuel mixture. If you snap the throttle back, the door in the AFM is shutting and may be causing the fuel pump and COR relay to shut off.
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I have a new VAF.....so I don't think that's the problem....was a while ago though, that's why I replaced it......bought the new one off ebay for $154.68 free shipping and life time warranty...if any one is interested here's the link http://cgi.ebay.com/ebaymotors/1994-...item48394ffd16
Do you have the old one? Can you borrow a FACTORY, OEM MAF?
Last edited by buckz6319; 05-20-2010 at 05:22 PM. Reason: added..(I replaced the old VAFM because it had a bad air sensor and was throwing a code not because it was cutting out the en
