elocker pinion
Old 10-01-2012, 05:52 PM
Mandy Tuning's Avatar
elocker pinion
i have a elocker from a 96 runner,want to regear but dont want to mess with the pinion flange to look if its 27 spline or 29 cause is my daily driver. nitro gear now are 29 splines and will be easier if i dont need to spend some cash on a pinion flange.any thoughts?
Old 10-01-2012, 06:31 PM
BigBluePile's Avatar
Um....what?
Old 10-01-2012, 07:01 PM
pinion splines,some are 27 splines ,some are 29splines, i beleive all elocker are 29 but not sure.
Old 10-01-2012, 07:31 PM
And what exactly are you trying to do?
Old 10-02-2012, 03:35 AM
want to change gears,but nitro gears already came 29 splines on the pinion. yukon are 27splines, you need to change pinion flange if your doesnt match on splines. i want the correct ones,seems elocker are 29,but not sure.
Old 10-02-2012, 05:00 AM
waskillywabbit's Avatar
:wabbit2:
Old 10-02-2012, 07:49 AM
no one can help?
Old 10-02-2012, 08:54 AM
westjohns yota's Avatar
your best bet is too just pull the pinion flange off and count, if your regearing just buy a new flange anyways......
Old 10-02-2012, 06:47 PM
I've never noticed the pinion spline count when upgrading elocker gear sets.
Old 10-03-2012, 01:53 AM
totally a bro
Staff
vital22re's Avatar
Why don't you post a picture of what you're talking about willis.
Old 10-03-2012, 04:55 AM
Fossilized
Staff
dropzone's Avatar
Your are gonna get a master install kit right or were you planning on using used bearing?
Old 10-03-2012, 06:22 PM
If you order a r&p for an elocker it should be what you need.
Old 10-03-2012, 06:59 PM
this came out from a 60k miles 4 runner that never used the elocker, so going to use a mini kit.
Old 10-04-2012, 05:49 AM
Well good luck! You going to use a solid collar?
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
digitalracer
05-16-2016 03:57 AM
Odin
09-26-2015 06:56 PM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: elocker pinion
