electronic to mechanical speedometer ?
I have a 91 5speed , when i bought it i noticed the speedometer didnt work. figured it was a broken cable or something.
once i got home I checked it out and the transmission and transfer case has been swapped in from something newer with the electronic sender for the speedometer.
my question is , is it possible to change the electronic sender to the older mechanical type ?
and what i would need to do so.
I did search but only found people swaping the opposite way using a marlin crawler part that wont work for me.
I'm tired of "flowin with traffic"to gauge speed. especially when there is no other car other than a highway patrol following you...
yes .. very possable .
just get the "bolt on" speedo drive (used) , and swap it out with the electric one .. add the cable and attach it to your speedo cluster , and your done
I did the exact oposit on my trekker , I wanted the electronic unit
Dennisx2
08-04-2015 01:26 PM
altydog
07-28-2015 10:20 AM
