ecu ground wire
Old 07-10-2013, 07:10 PM
YotaCurly's Avatar
ecu ground wire
i have a 1992 toyota pickup with a 3vze i was wondering if anyone knows if the computer has its own ground wire ? if so what color is it ? thanks guys
Old 07-10-2013, 11:18 PM
wyoming9's Avatar
Red face
Yes it has quite a few Ground wires.
They are brown bolted to a cam shaft bearing cap when it left the factory.
Old 07-11-2013, 11:35 AM
YotaCurly's Avatar
Let me rephrase this what color wire from the ecu's three plugs is actually the ground ?
Old 07-11-2013, 01:26 PM
rustypigeon's Avatar
Here is a link that tells you what each pin for the ECU is for. The ones that start with an "E" are the grounds. They are usually brown, or brown with a black stripe.
Go to page EG2-184 on this link...
http://personal.utulsa.edu/~nathan-b...86troubles.pdf
Old 07-11-2013, 09:34 PM
YotaCurly's Avatar
Thanks man I appreciate it
okamikai
04-30-2018 10:19 PM
Doug4320
03-24-2018 10:11 PM
montanatruck
02-26-2017 07:07 AM
Daneums
07-28-2015 11:57 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: ecu ground wire
