Driveshaft vibration
Old 10-27-2009, 03:44 PM
scottydogg's Avatar
Started having a vibration this morning. Crawled under and seen the driveshaft is vibrating. It only does this while the it is in out of gear. If you step on the clutch, brake or apply the emergency brake it stops.
Has anybody had this problem before and if so, what did they do to fix this?
Old 10-27-2009, 03:46 PM
abecedarian's Avatar
check the u-joints, tail shaft and pinion shaft
Old 10-27-2009, 04:11 PM
kennyyoung's Avatar
Also check for wear on your center bearing.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
hiluxinargentina
09-30-2015 05:51 PM
JPV
09-28-2015 03:15 PM
Odin
09-26-2015 06:56 PM
Quick Reply: Driveshaft vibration
