Does AFM harness connector look like this?
Old 09-24-2016, 08:11 AM
sam_KOR's Avatar
Hi! I have a 94 4runner 3.0. I was wondering if my connector is missing a metal connection(3rd one from the left) or if the connector is just like this from the factory. Please verify and help me please!!!
Old 09-24-2016, 02:42 PM
wyoming9's Avatar
No that is correct 12X4567
You did not get this figured out yet
FYI pins 1 and 2 are the switch
Old 09-24-2016, 02:49 PM
sam_KOR's Avatar
Thank you for verifying that this is correct.
You are correct. I haven't figured it out yet.. and thank you for your previous advice on FP and b+ jumping. It totally worked and the pump was working which means the COR is not operational.
I'm checking compressions in each cylinder now. I know.. I should have done that first but I doubt compression is the problem. I'm leaning more towards TPS issue and a defective AFM. I was testing the AFM connectors and all the resistance on them were either 0 or something way off from what this video had:
Would you please give me some advice what might go wrong? You are my only hope man..
nbl300
09-16-2016 09:35 PM
shadowstewie
09-15-2016 05:03 AM
sam_KOR
09-11-2016 11:05 AM
Daniel Pelkey
09-10-2016 01:10 PM
Quick Reply: Does AFM harness connector look like this?
