Diagnosis question
Old 12-10-2014, 11:36 AM
Peart130's Avatar
Diagnosis question
So real quick, is there any way to check the computer for the codes without having to have someone plug into it??
I was told I can jump two wires on the plug, but I don't know which ones.
'94 22re
Old 12-10-2014, 11:44 AM
UZI - SUICIDE's Avatar
1. initial conditions
Battery Voltage is above11 volts
Throttle valve fully closed (tps points closed)
In neutral
Accesories off
engine warm
2. turn on key but dont start
3. Short terminals T-E of the check engine connector located near the ignition coil
4. read codes of check engine lite
JHalcyonM
08-04-2015 01:19 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
rushw
07-18-2015 01:46 PM
Quick Reply: Diagnosis question
