dash lights/electrical badness
Old 08-10-2010, 10:05 AM
BEAHRDOG's Avatar
Exclamation dash lights/electrical badness
Got a block away from home and my truck decided to throw me another curve ball...
While idling, all seems fine... hit the gas, rpm goes up as it should and I see these light up...
then I notice this
oh.. and the faint smell of...burning...
would I be right to assume that I am in need of a new alternator?
also, can anyone tell me what the light on the left means?
Old 08-10-2010, 10:15 AM
myyota's Avatar
An alternators internal regulator can go bad and over charge a battery big time, i had this happen to me once and by the time i could stop the battery was boiling. I had to replace the alternator and the battery. Not real sure what the light on the left is ?.
Old 08-10-2010, 12:49 PM
BEAHRDOG's Avatar
indeed... pulled some wrenches... unplugged some stuff... and confirmed... it is the alternator...
good thing it's summer, and I have a motorcycle...
Old 08-14-2010, 10:09 AM
BEAHRDOG's Avatar
grrrr.....
okay! ... my truck doesn't seem to have much love for me... Bought and bolted in a brand new alternator (OEM), and now it has a high idle... like the engine is still warming up.
I start it, and is goes to 1250rpm, then slowly climbs... after driving a bit, I throw it in park, and it jumps to about 1700-1900rpm...
If I unplug the new alt, it seems to go back to normal... any ideas?
Old 08-14-2010, 10:23 AM
iamsuperbleeder's Avatar
did you replace the battery too?
if not, at least try unplugging it for a little while; like 10 or 15 minutes, and let the ECM reset, and see if that helps
Old 08-14-2010, 10:39 AM
BEAHRDOG's Avatar
Didn't replace the battery.. It seems fine. And I just had it unplugged for about an hour, and no change.
Old 08-14-2010, 10:44 AM
oh...
I think I'd have that new alternator tested, both in the truck, and bench tested out of the truck
my PU did this to me once too; overcharged and just about melted my Optima...
ended up replacing the battery AND the alternator...
jasonty
41
12-23-2018 01:00 PM
ghostmoney
01-28-2018 11:42 AM
mussy01
12-13-2016 08:20 PM
ViperTT
08-14-2015 05:27 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: dash lights/electrical badness
