coolant leak points on backside of 3vze
Hi guys, trying to locate a source of a coolant leak on my 1990 3vze.
(truck, 4wd xcab)
it is inconsistent, not necessarily all the time drip, but only sometimes, but at times its a pretty good stream that runs down from near the top of the transmission and onto the ground. other times, not a drop.
i originally thought it was the u hose or the coolant temp sensors or anything in that area, (and replaced those things) but even as it is pouring coolant, that area is dry. which most likely means it is below that area. probably close to where the Y pipe hides everything.
so what is around there? freeze plugs? the inconsistency is strange, but i have no good theories.
help!
(truck, 4wd xcab)
help!
(truck, 4wd xcab)
help!
(truck, 4wd xcab)
help!
Chris
Im looking for an answer as well. my 91 4runner just started leaking in the rear of the engine after i just did a radiator swap. I cant see the leak point and it does not appear to be a hose. any help would be nice!
sadly nope, still havent found the source. not really looking for it though, pulling the engine/cross over pipe is too much trouble to deal with now
Remove the hood & have someone rev the engine while you observe the upside down U-shaped bypass hose directly behind the plenum. That's the MOST likely leak location.
Dry all in that upper area now
jasonty
41
12-23-2018 01:00 PM
Avenged
07-09-2015 07:55 AM
