Coolant leak
Coolant leak
Just finished rebuilding my 22RE and it runs perfectly. Well other than the weird coolant leak. Coolant is seeping out of the bottom left corner of the timing cover. Where the cover meets the block and oil pan. It's not running down the side of the cover. There isn't coolant in the oil either. Doesn't over heat. All of the water passages are at the top of the cover near the water pump. What gives. I'm guessing I am going to have to put a new gasket on the timing cover and hope that takes care of it. Anybody run into this before?
Blamalam
03-12-2022 07:34 AM
WellsR
12
07-31-2015 03:27 PM
itzmywife's
07-25-2015 04:55 PM
Avenged
07-09-2015 07:55 AM
