coolant is coming out of cab
Old 01-12-2014, 07:47 AM
92yote4x4's Avatar
Hello i just recently swapped motors on my 92 toyota pick up wih a 4runner motor that needed head gaskets, i fixed head gaskets installed motor and i have coolant coming out of my cab on my drivers side next to frame and out of where there is a crease i uave no idea why it is doing this. Any help is greatly appreciated, also there is no coolant in oil or oil in coolant.
Old 01-12-2014, 07:53 AM
rworegon's Avatar
Possibly sounds like you did not hook a coolant or heater hose up correctly when you installed the motor. Anything on the passenger side?
Old 01-12-2014, 08:03 AM
92yote4x4's Avatar
The only thing i did unhook that dealt with the heater was the hose going into the cab closes to the fender but it seems fine tho and heat is hot
Old 01-12-2014, 10:14 PM
Gamefreakgc's Avatar
Like in the cab behind your dash? That's probably a heater hose to your heater core which is in the cab. No other coolant lines would leak in the cab unless something is hooked up really wrong like rworegon said.
Road Bull
10-10-2015 04:55 PM
mdev126
10-04-2015 04:48 AM
Poncho0206
07-10-2015 06:21 PM
bryan34w
07-06-2015 05:53 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: coolant is coming out of cab
