control arms
control arms
91 runner with ifs. Upper ball joints are bad and its getting to be time to replace the bushings. Rather than do all this with stock stamped steel control arms I would like to just get some aftermarket tube steel control arms with stronger ball joints. Is this possible? Also can I get a few links to aftermarket sites for other parts please?.
I have replaced both the upper and lower ball joints 2x b4 in 3 years of having the truck. The bushings where replaced about 5yrs ago and while where not gone would like to them to be safe. living in NM desert help with no rust but tears anything rubber or poly apart in short time. Was hopping maybe there where aftermarket arm I could use that would be stronger and last little longer and help reduce weight.
kawazx636
10-06-2021 03:03 PM
kcaudill
10-10-2015 02:39 PM
JookUpVandetti
09-30-2015 08:58 AM
