Control Arm Creak
RAD, I might be having the same issue, but I'm 85% sure that mine is actually just a loose shock. It only happens on the driver's side, hard break, turn, or accelerate. Been this way for as long as I have had it.
https://www.youtube.com/watch?v=g3qmBKTtcCM
Initially I also suspected my upper shock mounting.
This is my upper mount:
I found signs of shock mounting rod not centered with previous shocks.
So (before I found the issue with the control arm), I inspected my couple of year-old shocks for above problem, but found none. Then, I removed both shocks and drove slowly around the neighborhood, including speed bumps. Creak remained
NEKExplorer
09-18-2016 01:08 AM
FS[FourCorners]: APOR uni-ball Upper Control Arms - 95.5-04 Taco, 96-02 T4R
theferg
09-05-2016 09:08 AM
