Cold low RPM hesitation
Old 12-28-2008, 06:22 PM
pathfinder's Avatar
My '90 V6 has a bit of a low rpm hesitation when it's cold for the first few mintues after start up. It's mostly noticeable off idle, when leaving a stop, etc. Once she's warm it disappears. It's more of an annoyance than a real issue. Cold start valve/injector?
Thanks guys,
Brent.
Old 12-28-2008, 06:54 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Sounds like the Cold Start Injector is clogged up a bit.
Old 12-28-2008, 07:14 PM
abecedarian's Avatar
The cold start injector is only supposed to work during cranking to start. After the engine starts the ECU is able to calculate a fuel mixture based on intake air temperature, throttle position, coolant temp and air flow. To help the idle out when cold, there's a valve under the throttle body that opens up and allows air to bypass the throttle plate thus raising the engine idle a bit.
Do you know what your cold and warm idle rpms are? Cold could be as high as 1600 and warm should be 800, and it should definitely idle higher cold than warm.
Other things could be: plugs- if the gap is not correct, the rich mixture when cold could foul one or more plugs; coolant temp sensor- if it's malfunctioning the ECU may think the engine is warmer or colder than it really is and inject the wrong amount of fuel; throttle position sensor- if that's maladjusted or failing, the ECU may think the throttle is at a different position than it is and inject the incorrect amount of fuel; and as always, vacuum leaks could affect engine operation. I would probably shy away from the air flow meter, but the air temp sensor in the meter could be sending an incorrect reading and mucking with the air-fuel ratio. There's also the possibility that the EGR valve is not operating properly or you have one or more partially clogged injector(s) that is/are not able to supply enough fuel, but since it runs fine when warm I would probably not concern myself with that until it's the last resort.
It's likely running fine when warm because the O2 sensor has warmed up and gives some feedback to the ECU allowing it to fine tune the mixture.
Old 03-01-2012, 09:00 PM
markwils's Avatar
Did you figure this one out? I have the exact same symptoms. Also my truck runs cold at highway speeds, I dont know if it is related I have a 4'' body lift that could be cooling it off.
Old 04-25-2012, 07:18 PM
macneill5's Avatar
I have had similar symptoms with my 90 4runner V6... where it will idle low and rough when the car is started when the engine is hot.
i thought it would be the IAC valve, any ideas?
Sleaker
08-26-2020 06:03 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
JefferDean
07-31-2015 10:39 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
ty1er
07-19-2015 06:42 PM
Quick Reply: Cold low RPM hesitation
