cigarette lighter help
Old 12-22-2008, 10:13 AM
g_mau18's Avatar
My cig lighter doesnt work and I need it for my phone and gps, whats the best way to fix this? god im such a newb
Old 12-22-2008, 10:16 AM
rdlsz24's Avatar
Check out your fuse block down by your feet. There is a cig fuse if I remember correctly.
Rob
Old 12-22-2008, 10:23 AM
g_mau18's Avatar
so all it could be is a blown fuse? Man I have a hard time with the electronic stuff
Old 12-22-2008, 10:56 AM
93ToyKid's Avatar
they also come unplugged really easy from the back. check that if the fuse is blown...
Old 12-22-2008, 10:57 AM
93ToyKid's Avatar
if the fuse ISN'T blown, as it were...
Old 12-22-2008, 10:59 AM
g_mau18's Avatar
could someone walk me through the basics of getting my cig lighter to work?
Old 12-22-2008, 11:00 AM
g_mau18's Avatar
i got an 88 pickup, theres no fuse panel to the left of my feet
Old 12-22-2008, 11:08 AM
Co-Founder/Administrator
Staff
Corey's Avatar
If the fuse is not blown, then your fusible link is.
That is a fuse that is built into the wiring a few inches away from the cig lighter plug.
It often will melt if to high of an appliance was plugged into the socket.
Best way to fix that is to over ride it and put in a straight wire of the same diameter.
If you do not have a fuse though for yours though, I would install one along with the new wire.
Mine blew out on my '90 Extracab I had, and I just replaced it with a wire.
But it was fused too though from the fusebox.
You can see a fusible link here.
http://www.wefixittogether.com/?p=25
Old 12-22-2008, 11:14 AM
algranger's Avatar
if all that doesnt work check your ground. they can get corroded and short out
Old 12-22-2008, 11:20 AM
scuba's Avatar
mine didnt work, it was rusted and the posts that are inside needed to be pulled out a little, sitck a flat head in there and bend them outward a little...
Old 12-22-2008, 11:21 AM
algranger's Avatar
Originally Posted by scuba
i was rusted
dont ya hate when that happens?
Old 12-22-2008, 11:27 AM
4Crawler's Avatar
Here is a writeup on replacing the fusible link:
http://atv.off-road.com/atv/article/....jsp?id=186346
Mine blew out about 10 years ago and I just soldered the two ends of the link wires back together where the link metal had melted away. Also a good time to repower that item froma constant 12 volt source so you have power all the time.
Old 12-22-2008, 11:36 AM
smartboyalex's Avatar
I second whole fuse then connection thing. Mine came unplugged just from driving on rough roads I guess. It is super easy to plug back in. It is a male and female post type connection that goes right into the back of the cig lighter. Good Luck
Old 12-22-2008, 11:53 AM
scuba's Avatar
Yeah, sorta like when my carb doesnt run right
Mrhoadley
08-04-2015 06:08 PM
TDonkey
07-26-2015 10:14 AM
bigblue82
10
07-06-2015 08:27 AM
CUBERA
11-21-2003 03:19 AM
venom79
86
08-13-2003 10:06 AM
Quick Reply: cigarette lighter help
