Check before I rebuild the carb
Old 08-18-2008, 11:32 AM
aerocorey's Avatar
I came into an '86 5 speed pickup with a 22R. I got it with 230000 miles, a blown head gasket, a worn timing chain, and a clutch down to the rivets. I did all the work and fired it up...it idled like crap. I pulled the carb and found the passenger side butterfly completely crusted shut. I've done the best I can cleaning and adjusting the carb without taking it apart, but it's not good. Before I freed and cleaned up what I could it idled rough. Now it idles high, and I can't adjust it down. If I leave it running for more than about 10 seconds it stumbles and dies. I'm sure a carb rebuild will cure my woes, but I'm looking at at least a week wait on parts. I checked timing, compression is around 155 across the board, valve clearances adjusted, vacuum is 20 with no apparent leaks. Anything else I should check before tear into the carb? Also, when I cleaned the carb I pulled the passenger side butterfly pivot shaft out of the carb. I didn't see any seals in there, did I miss something?
Old 08-18-2008, 02:23 PM
slisdexia's Avatar
I cant give you any advice as to what to do, I just found my own rough idle problem is due to air leaking through strange places in the carb, apparently quite a bit through the fuel banjo seals. I guess I'd check there too if I was you, along with other place that may leak air
bigjstang
08-25-2021 12:41 AM
dumpster84
04-30-2016 06:03 AM
jerusry
10-19-2015 05:28 PM
calderp
07-27-2015 09:58 AM
Yota.Jay
07-23-2015 08:08 PM
Quick Reply: Check before I rebuild the carb
