Charge light comes on when putting in reverse
Hey guys, got kind of a weird problem here. My turn signals didn't work so I checked the fuse and my HAZ-HORN fuse was blown. So I replaced the fuse and the turn signals worked for a couple minutes but then I started having problems again where the charge light would come on at every blink. I didn't want to get myself stranded so I just pulled the fuse.
Now, for some reason, every time I put the car in reverse, the charge light comes on for a second, the lights dim, charge light goes off, then everything is fine. What could this be?!?
Yep pull the rear tail light assembly and inspect the wires on both sides of the wire grommet where it passes thru the sheet metal. And inspect your tailer harness, You might have one tucked up under the frame and not know it so don't just assume it's not there.
If you can't find anything visually in the wires use a meter and test for shorts to ground. If you still don't find anything inspect all the bulbs carefully, in some cases the wire that holds the filament will short out with the other and it's then a direct short to ground.
Well I just disconnected the reverse switch from the trans for now until I can figure out this issue. I really don't need reverse lights, but working turn signals would be awesome.
You could also inspect the relays and wiring in the dirvers side kick panel. and inspect the integration relay while you're in there.
Most/All of that is covered in the manual.
Feel free to post up questions to clarify anything you're having problems understanding or performing.
If you don't have a test meter they're less than 5$ at the local harborfreight. Even walmart has cheapones alot of times.
ashersullivan88yota
01-18-2022 05:37 PM
09-04-2015 09:27 AM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
