changing crank seal
Not to sound like a jerk, but I would recommend that you pick up a manual. It will answer 99% of the questions you are going to have. Since you are going to have to remove the timing belt to replace the crank seal and depending on how many miles you have your engine, you might as well replace the timing belt and water pump. Good luck
i thought my front seal was leaking once and when i was puting it all back together i noticed the oil pan bolts were loose. i probably didn;t have a seal leak afterall.
jasonty
41
12-23-2018 01:00 PM
