carb efi swap
Old 09-24-2008, 07:03 PM
myyota89's Avatar
Question carb efi swap
i blew the motor up in my 89. i can get a rebuilt 22r for next to nothing, but i want efi. is it possible change the 22r over and make in efi or am i better off getting a 22re motor, or can i just run the carb motor in my truck.
Old 09-24-2008, 07:04 PM
scuba's Avatar
both are possible with a bit of work.
Try searching about this topic, its very well covered
Old 09-24-2008, 07:07 PM
toy power's Avatar
they are exactly the same motor as long as the 22r is newer than 84
TOYOTA 1's Avatar
your efi will bolt up to 85 or newer 22r's iirc.
just have to swap out your distributer and the sensors on your block!
there is a bunch of info on that subject already, try searching and see what you can find!
Old 09-24-2008, 07:09 PM
ozziesironmanoffroad's Avatar
what im waitin to see is someone take EFI and switch it over to carb... honestly i prefer carbs but the EFI hasnt given me a problem...
Old 09-24-2008, 07:32 PM
abecedarian's Avatar
from what I've heard...
the 22r head is missing some bolt holes for the EFI manifold.
the 22r head can be welded up, drilled and tapped for the EFI manifold though.
also, there is allegedly a difference between the cams for the carb'd and efi'd engines.
Old 09-24-2008, 09:00 PM
drew303's Avatar
Get the 22r and put your EFI on it. Your lucky in the sense you have everything right there and don't have to search around for the misc things.
What year is the 22r?
EFI manifold will bolt up to a 22R head, well the 22R/22RE heads are identical. Except some have oval vs pear shaped exhaust ports.
There were some differences in the 85 and older EFI setups but don't ask me for details.
Old 09-26-2008, 05:55 PM
escodan760's Avatar
22r 4WD to 22RE efi
I want to convert to efi and found a motor harness and ecu from a 1992 2wd. my truck is a 1986 4wd. does it matter if Im putting a 2wd motor in mine
Old 09-26-2008, 06:00 PM
Staff
DeathCougar's Avatar
Nope. All 22R and 22RE heads from 85-95 are EXACTLY the same.
Only difference is the 22R engine uses a cam eccentric for the fuel pump, and the 22RE uses a spacer and a block plate to fill the pump hole.
Old 09-26-2008, 06:02 PM
Staff
The harness will be different, you will have to swap the oil pan, but it should be ok otherwise.
Old 09-26-2008, 06:08 PM
escodan760's Avatar
cool thanks man.
Old 11-14-2009, 11:53 AM
MIyota87's Avatar
carb to efi
I have an 87' 22r motor thats carb and i want to put it in an 88' that had an 22r that had efi will it work
Old 12-02-2009, 12:15 AM
The84toyota's Avatar
hehehe another question Ive got the re and r and want the e on the plain r to make it a re wheeeehehehee so a How hard is the wiring gonna be? Will it plug in the cab harness? There is a junction split between cab and engine wiring to unplug it all right?
tomczaksdiesel
07-26-2015 10:35 PM
keithporter83
07-24-2015 07:37 AM
Yota.Jay
07-23-2015 08:08 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: carb efi swap
