Can any one explain this ?
Old 02-28-2008, 06:47 PM
keithguts's Avatar
I have a 1995 4runner 3.0
My question is, why when I have the heat on in the rig, and I make a left turn, the heat gets hotter.
Seems strange to me.
Old 02-28-2008, 06:57 PM
James Dean's Avatar
Short of something getting moved when you turn the steering wheel that changes a setting, it might just be the air rotating in the cab as you turn and your hitting a warmer batch. This happens in my 91 with a shell, no window and a boot to the back. I'm guessing the same could happen in a runner.
Old 02-28-2008, 07:44 PM
stupid_mud_gremlins's Avatar
A left turn would make the coolant pull to the right...isn't that where the inlet to the heater core is? Possibly low on coolant?
Old 02-29-2008, 06:37 AM
InternetRoadkill's Avatar
The air is sloshing inside the cab. It would seem that your heater is heating unevenly.
Old 02-29-2008, 07:36 AM
Brenjen's Avatar
I'm sort of with stupid mud gremlins on this point, except maybe instead of just low you have an air bubble which would still be technically low.
Old 02-29-2008, 01:13 PM
keithguts's Avatar
So, how do you correct this. It has done this since I got the rig. I also had the compleat top end done about 1 year ago, and it still does it. O, and by the way, I didn't get the top end done for that reason LOL. I also want to say that the coolent level is right on.
Old 02-29-2008, 08:56 PM
James Dean's Avatar
Quit making left turns.
mulewright
09-28-2015 10:27 AM
pthunter
09-02-2015 02:26 AM
Foage3z
Florida
08-31-2015 04:49 PM
altydog
08-28-2015 07:01 AM
Quick Reply: Can any one explain this ?
