A/C compatibility
A/C compatibility
My truck is a 1993 base model. I've been adding a bunch of options as I find them but I'm stumped on the a/c system. I've read that a 4 runner ac won't swap into a pickup, although the dash and interior is mostly the same. Can anyone clarify this? Is it physical size that is the problem? Can it be made to fit? 4runners here are all over the place and trucks are few and far between. I want this in before summer.
Thanks.
Thanks.
When the 4 runner got the face lift in 91-92 and switched to modular headlamps from the sealed beams the a/c condenser also gained a fan because the a/c has to work harder to cool more space, and the new updated front end had the clearance for it. You don't need the fan, and it will also not fit on the truck.
I'm in the process of getting all the a/c parts together for my truck but it's really tough to find for the 22RE. Goal it to have it in this summer too.
One big item on your shopping list will be the cooling unit (houses the evaporator and a/c control amplifier). This mounts in behind the glove box in the place of a "dummy" section of ducting. I have found (at least on 2nd gen 4Runners) that there are at least 2 different configurations for the cooling unit. I suggest you check out http://www.toyodiy.com/parts/ enter your VIN then navigate the parts to section 4 "electrical", then "87-14: HEATING & AIR CONDITIONING - COOLER UNIT". Get the part number for the "UNIT ASSY, COOLER" and you can do a cross-reference to see what other vehicles use that part (http://www.toyodiy.com/parts/xref). I ended up buying a cooling unit from a 1990 on a whim and it's not matching up to my wiring harness on the truck.
Another thing you don't want to miss is the VSV (vacuum switching valve) "idle-up" system (basically a vacuum switch, diaphragm actuator and vacuum tubing) that the amplifier controls to increase your idle speed when the a/c compressor kicks in.
I'm still trying to figure out all the details myself but I hope this helps a little.
And the amplifier control on top the evaporator core does not control the a/c
idle speed. It controls at what RPM speed the clutch on your pump engages. If it
is set for 1,200rpm, when you sit at a stop light idling at 800rpm the a/c pump
will turn off.
will turn off.
kawazx636
10-06-2021 03:03 PM
bryan34w
12
09-30-2015 02:50 PM
