Broken Oil pressure switch question
Old 03-27-2015, 12:16 AM
andrewtexas123's Avatar
Hey guys I accdentally snapped my oil pressure switch and then tried to remove it with a thread extractor which broke
So then I couldnt get my center punch centered and messed it all up.
Can I weld it shut and relocate the switch? There is a plug in my block (circled in pic) can I move the switch there?
Thanks
Old 03-27-2015, 03:16 AM
Staff
Terrys87's Avatar
You probably used one of those swirled extractors and they are brittle and will snap easily, done the same thing myself. Those should be outlawed. Teh square extractor is more forgiving.
What I did was put a washer and a nut over the broken extractor and welded the nut to it and it came out.
Old 03-27-2015, 07:19 AM
scope103's Avatar
Xylicon recently posted about using that port for a second sender. https://www.yotatech.com/forums/f116...l-port-287580/ Note that the port is "inside" the motor mount, which limits the amount of space (but didn't hurt Xylicon's efforts).
Screw extractors, even the "square" ones, are designed to be very hard and therefore brittle. Using one is always risky; once you're broken it off you cannot drill it out (the extractor is harder than the drill). The weld-on-the-nut method described by Terrys87 does work, but requires some welding talent. (Enough of which I don't think I have.)
Old 03-27-2015, 07:36 PM
xylicon's Avatar
Yes, it is a tight fit, but there is no interference.
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
09-04-2015 09:27 AM
Huntingtruckcletus
07-08-2015 05:26 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: Broken Oil pressure switch question
