broke out a lift block now fixed and no brake pressure!!!!
ok like the title says last weekend i was wheeling at my lift block broke and my leaf springs came apart long story short i towed the vehicle home and got a new lift block kit and got everything squared away. however know my brake pedal has no pressure the brakes work but not very well. i can pump the brakes and they have pressure but only for a few seconds. i have tried bleading the brakes several times and have looked everywhere for leaks i cant find any. can anyone help me with this?
here is something else that seems odd to me when the truck is off and you pump the brakes everything is good has good pressure. when you turn the truck on the brakes seem fine but when you put it in gear and rolling it goes to the floor.
You bleed the wheel cylinder which is furthest away from the master first. Given that the brake line comes down the pass side frame rail, the Left Rear wheel cylinder is the furthest away, using the longest amount of line. So it should be bled LR > RR > RF > LF
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
