Brake upgrade question.
My 86 4Runner has a solid axle up front, and i plan on upgrading to vented rotors soon. Once you have the vented rotors and the V6 calipers, is it just a matter of swapping the vented rotors and V6 calipers for the original parts and thats it ?. I have 15x10 rims on my 4Runner, will i have any clearance issues with the larger calipers and my rims ?. Can i use brake calipers from any year V6 truck or 4Runner ?.
Take a look at Wab's site: http://www.wabfab.org/products/brakes/brakes.htm
Thanks guys, but i still need answers to my questions. Can i use V6 calipers from any year truck/4Runner ?. Will i have clearance issues with the larger calipers and my 15" rims ?, and if needed can i grind the calipers a little for clearance ?.
No clearance issues for 15" rims...they came stock with 15s
Only problem will be the dust sheild needs to be trimmed about an inch on both sides of the caliper...
Get yourself a 1" Master cylinder while your at it.
Thanks again
also depends on your backspacing of rims...
my buddy had a problem with his calipers hitting on his 15 inch rims....
changed rims to ones with different backspacing and problem solved... so put them on and try it.. lol...
can i grind the calipers a little if needed to clearance them a little ?, i don`t really want to use wheel spacers unless i have to.
Im not 100 % sure.
Anybody else kno?
I wouldnt grind on my caliper tho. Just my own preference.
I think the rims you have are what my buddy have. So you should be fine.
Only one way to find out tho. Haha
Anybody else kno?
You have never heard of doing this before ?. Im not talking about grinding alot of metal off the caliper, just a very little if needed. Otherwise i would just buy some wheel spacers.
06-01-2021 01:51 PM
94ofCanada
08-14-2015 06:37 AM
