Brake line leak
Brake line leak
1995 Pick-up, 4WD, Manual, 22RE
Anyone know where I can find the brake line part right beside the gas tank.....It's leaking like a seive when I step on the pedal. I can't find it anywhere online, but have not called the dealer yet?
Thanks!
Thanks!
Your looking for the exact part number/a place to order it?
Use this place for finding the exact part number:http://www.toyodiy.com/parts/
And I have purchased from: https://www.1sttoyotaparts.com
Just a note, if your going to replace it with a factory line, you may have to drop you gas tank since its in a poorly accessible location.
the brake line "part"? are you talking about an actual brake line, or are you talking about the LSPV (load sensing proportioning valve)? the LSPV looks like a little block with i think 3 brake lines going in to it and then a steel rod that goes between it and the axle. is this the part you're talking about? if it is, i found a used one on yotatech when mine went bad. if you're just talking about a brake line, any auto parts store will have one that will work.
this is an LSPV:
this is an LSPV:
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
