Bracket holding auto transmission cooler lines
There is a bracket that holds both aluminum hardlines from the transmission to the radiator. Can somebody take a quick look to see where this bracket mounts to and approximately what angle the bracket mounting surface is relative to the surface holding the hardlined? I think mine is bent to fit into an alternate location (after the hardlines were cut).
Thanks!
Thanks!
