Blower not blowing so hard
My a/c blower isn't blowing as hard as it used to. Could anyone tell me where I can look to fix it? Do I have a cabin air filter?
Thanks.
Lol forgot to add model year. It's a 1987.
Thanks.
Since you posted in the 1986-1995 truck section, I will assume you are working on a truck in this year range.
These trucks did not have any cabin air filter to stop the debris from flowing through the system. Your truck has A/C, so you probably have a lot of leaves and other junk blocking air flow across the evaporator.
If your truck did not have A/C, you would have have the junk blocking the heater core.
Check for debris in the system first.
Terrys87 did a great write up for cleaning the ventilation system. I will post it here once I find it.
Found the thread : https://www.yotatech.com/forums/f116...trucks-286766/
This is for 1984-1988 trucks but 1989-1995 should be similar.
