Bed Removal
Staff
Once they start spinning, I always have to cut the bolts off. Usually the tab up in the bed has bent and no way to access it until the bolt is cut off and then lift the bed to get the tab out of the slot. I have cut many a bolt on the bed.
bed bolt removal
Cut them off? I am afraid if I use a torch, the whole bed will catch on fire. I am not sure how else to cut them off. I have not ruled out a torch.
Thank you for your advice.
Staff
I use an electric cut off saw if the bed bolts have spun a few times to get the blade in there. I also have a pea grinder with a small blade on it that lets me get to some if there is not much room to get access to them.
FS[PacNorWest]: 1988 Toyota Pickup 4x4 Long Travel - Seattle, WA - $6500
96taco4x4
02-06-2020 05:16 PM
Thomas Reynolds
11-03-2016 07:17 AM
Mr.Chubbles
08-13-2016 11:49 AM
