bad acceleration and sputtering at low rpm
Old 10-21-2013, 12:56 PM
bthompsonwyak's Avatar
My truck has been acting up for awhile now. When I accelerate it seems something is clogged or not firing until I reach an rpm when it just goes until I shift. Any ideas or similar troubleshoot.
Old 10-21-2013, 03:28 PM
ksti's Avatar
Does this rig have a motor?
Old 10-21-2013, 04:13 PM
mylittlepony1's Avatar
No, it has an engine
Old 10-21-2013, 05:05 PM
ksti's Avatar
Are you some kind of smart ass?
If your going to post stupid **it, then maybe you should find a kiddie forum.
Old 10-21-2013, 05:09 PM
Kiddie forum, huh? It's obvious who the immature one is. At least I know the difference between an engine and a motor. Learn to take a joke like an adult.
Old 10-21-2013, 05:20 PM
Yes. And it is getting annoying. Do you know anything about fuel or efi
Old 10-21-2013, 05:27 PM
We're gonna need a bit more info about your truck. What size engine does it have? Have you recently done a tune up? Sounds like a bad fuel filter
Old 10-21-2013, 05:40 PM
91 toyota pickup 22re 4wd spark plugs last year. Fuel filter before a fuel pump and gas tank. Could be clogged again. Seems to happen more when wet
Old 10-21-2013, 06:19 PM
Try something cheap first, like a fuel injector cleaner or fuel system cleaner. That just might do the trick.
Old 10-21-2013, 07:46 PM
ksti's Avatar
If it's worse when wet, then it's possible your getting moisture
on some wiring or connection.
Also check for frayed wires and also make sure all your grounds are clean and tight.
Charecter1
11-06-2023 10:08 AM
Sleaker
08-26-2020 06:03 AM
smiley52
07-11-2015 05:16 AM
88runnergomas
07-09-2015 01:12 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: bad acceleration and sputtering at low rpm
