Back window help
Back window help
Got a 94 4R, the back window rolls down fine but doesn't want to roll up. When you turn the key I can hear the relay click every time I try, I have to try multiple times before it finally rolls up, does anyone know what could be wrong or how I should just bypass it some how? I hate wire work but it needs done because I use my window a good bit. Thanks guys.
It only does it when I try to roll it up, it will go down every time. But when I try to get it to go back up I got to keep turning the switch till I get lucky and decided to go up and it goes up strong and fast it is just getting lucky and hoping it goes up
No it does the same weather it be the switch up front or the key turn on the hatch, Iv tried wiggling the wires by the motor and I'm the guts of the window and by the relay and nothing seems to help. It just wants to work when it wants to, I'm no electrician so this is a huge pain in the ass
Location: exo-reality -wave if you see me; Front Range, CO
If you get some copy of the FSM, you can easily identify the final plug for the motor in the rear. You'll have to pull the cover and whatever that plastic sheet is called off. I'm got mine tore apart, and had to pull the gate off few days ago to attend to some rust issues. Put a couple of jumpers into the plug, and using a battery you can make it go up or down depending on polarity. If there's not any issue going direct, you can then assume you have some sort of harness issue. Also, as WYO suggests, you can also pull out the mechanism and clean and lubricate it properly.
cryptkeeper
09-26-2016 08:12 AM
