Anyone ever removed Radiator/Core Support
Old 09-27-2011, 10:53 AM
dsal_86Yota's Avatar
Gotta replace the radiator/Core support for my 86 yota pickup. Pretty sure that its spot welded. Has anyone done it? Is it a pain? What all do I need for tools and what all will I need to do?
Old 09-27-2011, 11:45 AM
shaeff's Avatar
I've looked at it just to get a feel for what's involved. From what I could tell from my quick glance is that it would be pretty easy to remove with a decent spot weld drill.
I plan on removing mine for the motor swap that will eventually happen once life stops throwing me curve balls. LOL.
Old 09-27-2011, 12:31 PM
91muddog's Avatar
lol, yeah cutting all those spot welds is a royal pain! the welding back together is pretty easy. if your truck is wrecked, go for it!
Old 09-27-2011, 08:49 PM
Thanks guys. Looks like trip to welding shop or harbor freight got spot wels drill bit then few cut off wheels. Gonna get all parts 1st then start putting it together. Winter is parts collection time since all work is got to be done in backyard . Joy of no garage, not even a car port
Old 09-27-2011, 11:28 PM
wyoming9's Avatar
Smile
By far the best spot weld cutters I ever used were Snap On .
They are not cheap but less time spent replacing cutters was worth it for me.
I always used a 1/8" drill for my pilot hole . Have lots of those the shorter the better.
Old 09-28-2011, 07:35 AM
Thanks Wyo. Will see about finding a Snap On guy
shaeff's Avatar
Any time I've drilled spot welds, I just used a center punch and made a divot in the center of the spot. Then commence the drilling with the spot weld driller. Worked great every time. There's actually an article in 4WD Toyota Owner Magazine this month about drilling spot welds and two good bits they used, but they highly recommended them. I'll look at the brand when I get home and post it up.
I wish they'd go monthly on that magazine!
Old 09-28-2011, 09:10 PM
Will have to get that one. Haven't got any of the 4wd Toyota magazines
Old 09-28-2011, 11:11 PM
JamesD's Avatar
Core support is EASY to remove. You do not need any spot weld cutters. Just bring some drill bits. You have to unbolt the frame mounts, A/C brackets, power steering cooler line, headlights and wiring.
James
old87yota
09-09-2015 12:39 PM
kapeket
08-23-2015 12:51 PM
Pedalpwr27
08-13-2015 06:37 AM
nickbeauregard
12
08-07-2015 06:04 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Quick Reply: Anyone ever removed Radiator/Core Support
