Alternator Upgrade
Old 12-25-2008, 09:51 PM
myyota's Avatar
Alternator Upgrade
Has anyone upgraded there alternator to a 100 amp MR2 alternator, and if so
what did you need to do to make it fit ?, it looks like it would almost be a bolt in, but im sure some modifications are needed. any info is appreciated.
Old 12-27-2008, 05:02 PM
myyota's Avatar
^^Bump^^
Old 12-27-2008, 05:05 PM
the_ocho's Avatar
sounds like you should try it out and make it work. then do a write up. im sure lots of people would like this to work. i know i want a bigger alt
Old 12-27-2008, 05:43 PM
TacoNut's Avatar
Check out a Mean Green at LC engineering. 100A @ idle 140-200A @ running RPMs $369. Not cheap but a great alternator.
Old 12-27-2008, 06:02 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
You could also have your stock alt re-wound, I believe. As for the cost.....I don't know
Old 12-27-2008, 06:12 PM
Junkers88's Avatar
Unless you're running dual batteries and a butt load of lights is this really an upgrade?
Old 12-27-2008, 06:16 PM
TNRabbit's Avatar
Contact these guys:
Boyle Future Technology
12325 Locksley Lane
Auburn, CA 95602
Phone: 530-888-6290
more links:
https://www.yotatech.com/forums/f116/alt-swaps-93053/
https://www.yotatech.com/forums/f116...market-114474/
https://www.yotatech.com/forums/f116...attery-135096/
They can upgrade the stock wimpy 60 amp to 130 amp, 75 of which is available at idle! I paid $170.00 shipped both ways @ little over a year ago.
Old 12-27-2008, 06:33 PM
TacoNut's Avatar
130W lights x 2 21.6A
Compressor 15-30A
500W Amp 40A
Winch 40A
Depends on what your doing. Just the lights could be a strain on a factory alternator. I agree that the best thing would be a dual battery setup and an HO alternator. But if you only use the accessories only when the vehicle is running the alternator is fine. Personally I like to blast my stereo while winching and blinding everyone around me!!!
Old 12-27-2008, 06:35 PM
scuba's Avatar
Originally Posted by OremTacoNut
Personally I like to blast my stereo while blinding everyone around me!!!
Hah, x2, No Joke though...
Old 12-27-2008, 07:55 PM
abecedarian's Avatar
he said "winch" not "wench"
Old 12-27-2008, 07:57 PM
TacoNut's Avatar
Winch, Wench... Eh! Either one!
Old 12-27-2008, 08:55 PM
Jay351's Avatar
Defantly a mod in my future... Here is a link a friend sent me...
http://www.off-road.com/trucks4x4/ar....jsp?id=186492
Old 12-27-2008, 09:57 PM
myyota's Avatar
I have read this write up before, but its for a 3.slow V6, i have a 22RE in my 86 4Runner, so thats why i was asking what needs to be done to make it work ?.
Old 12-27-2008, 10:52 PM
Matt16's Avatar
Keep in mind: I just checked the FSM, the alternator is NOTthe same between the 3VZE and the 22RE. They use some of the same parts, so if you do a search and find posts by me saying they're the same, I was wrong, they aren't.
Old 12-28-2008, 05:05 AM
the_ocho's Avatar
somebody should make those brackets and sell them. I know i for one would buy one because i no longer have a welder.
Old 12-28-2008, 06:12 AM
seaofnames's Avatar
Upgrade the ground and power cables that run from the battery. That should be the first thing you do.
I'd personally get it rewound, then there are no fitment issues at all.
Old 12-28-2008, 06:40 AM
the_ocho's Avatar
Big 3 has been done.. what kind of shop would i go to to have it rewound. i know about
12325 Locksley Lane
Auburn, CA 95602
Phone: 530-888-6290
but i wanna find a shop local if i can.
Old 12-28-2008, 08:11 AM
TNRabbit's Avatar
I went to a local shop originally, but they told me they couldn't get a kit for the Toyota alternator. That's when I looked up Boyle. They add a new rectifier/diode as well....they are GREAT~Top notch work.
Old 12-28-2008, 08:17 AM
4Crawler's Avatar
Here is an option:
http://www.4x4wire.com/toyota/tech/alternator/
Old 12-28-2008, 09:10 AM
BigBluePile's Avatar
Originally Posted by 4Crawler
That's what I did. Worked great.
Quick Reply: Alternator Upgrade
