Aftermarket gears in factory 4.88 3rd
I grenaded a 4.88 rear yesterday and someone could rebuild it for me but I thought you can't put aftermarket gears in the 4.88 thirds
Is that the issue because factory? I would assume the quality is there from Toyota but guess it failed. What's the reasoning aftermarket gears won't fit the 4.88 housing? I'm running only 33s
the factory 4.88 is a thinner ring gear. the aftermarket 4.88 that you would put into a 4.10 or 4.30 diff is the same thickness, I believe.
XtraCab
04-12-2020 05:25 AM
jerusry
10-19-2015 05:28 PM
