ac clutch not engaging
Old 12-24-2014, 07:29 PM
83yotaman's Avatar
need your help. just replaced my blower resistor. all fan speeds works great. ac button light is on but compressor does not engage. There is pressure in ac system. There is only 1 wire that feeds to my compressor, i check it for voltage and nothing. Any ideas? thanks.
Old 12-25-2014, 12:22 AM
wyoming9's Avatar
Red face
If one of the pressure switches is not working correct
If your manifold gauges read in the proper range
The AC amplifier will not send system voltage to the clutch
It might help knowing just what year and model
Old 12-25-2014, 07:11 AM
83yotaman's Avatar
sorry, 91' 2.4l 5spd. I dont have gauges, but i do know there is pressure. i guess i need to get it checked out by the ac shop?
Old 12-25-2014, 08:03 AM
rustypigeon's Avatar
I would pull out the multimeter and check the voltage to the amplifier at pins 3 and 8. These are the pressure switch input pins. If you are not getting voltage there, I would check the pressure switch or verify that you indeed have pressure with gauges.
http://personal.utulsa.edu/~nathan-b...ng/22airco.pdf
This link shows where the connector pins are and the voltage values.
Old 12-25-2014, 11:46 AM
jennygirl's Avatar
I was gonna say, try checking farther up on that wire you are talking about. Mine was broken on the inside and worked after resectioning it. It sits in a pretty rough spot, perhaps you are getting voltage farther up in the harness and it's a simple broken wire
Old 12-25-2014, 06:26 PM
83yotaman's Avatar
thanks, I'll give that a try.
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
primordialbeast117
12-19-2015 12:23 PM
hiluxinargentina
09-30-2015 05:51 PM
JookUpVandetti
09-30-2015 08:58 AM
Quick Reply: ac clutch not engaging
