A340h solenoid replacement
Wanna tackle this job, doesn't seem that bad, just have a question regarding the parts. I'm looking for a kit for the 3 solenoids, filter, and gasket. I actually found one on amazon but it says it's for the a340 in 85 and up jeep Cherokees, it doesn't specifically name the "h", it just says a340. I was wondering if this would work or if anyone would know where I could pick up a kit that would work. I've included the amazon link, thanks.
Partsam Solenoid Service Kit Jeep A340 AW4 Transmission 1985-UP 2WD & 4WD For Cherokee https://www.amazon.com/dp/B01AZ7GPLA..._bgYUwbM8Y6KAH
http://m.ebay.com/itm/Toyota-A340E-A340F-Transmission-Solenoid-Kit-2-Shift-1-Lock-Up-3PC-Kit-A340E-F-/281781703567?nav=SEARCH
If that is a true stock photo, the filter is the wrong filter. When I did mine I had to purchase the solenoids as a kit and then the filter. There is a guy on eBay called "Motor City Trans Parts" that I purchased mine from and am happy with them so far. They have a smaller solenoid body, but are the proper part. The filter and gasket are like 20 buck, so it isn't to bad. Hope that helps, and here is the link. http://m.ebay.com/itm/Toyota-A340E-A...567?nav=SEARCH
"Fitment" charts usually work with the year of the vehicle. With enough work, you could figure out which year vehicles used the A340H, and then translate the fitment charts.
Personally, I start with a dealer site to get the actual part numbers I'm looking for. Try: http://www.toyotapartsoverstock.com/ Then, if I don't want an OEM part I'll look for an after-market reseller who will give me the part number he claims his parts replace.
I note that the eBay listings don't give the part numbers they claim they are replacing. The more recent one has a "compatibility" tool where you can put in your make/year/model. That one claims it fits my truck (which has an A340H), BUT it warns it won't fit a "4 solenoid model" (which IS an A340H).
I suppose you might get really, really lucky and find someone on this forum who has purchased the exact eBay item you're looking at, and can tell you reliably that it fits or doesn't. Good luck with that. Otherwise, you have some simple homework ahead of you.
mortievondee
01-19-2016 12:44 PM
