94 4runner won't shift to 5th
1994 3.0 automatic 158,000 miles. Driving on the freeway 70-75 mph and it won't shift at 4,000rpm. I just got an oil change, was told to try changing tranny fluid? Any ideas? OD going out?
Auto should be a 4 speed?
You should check the AT fluid level, the shifter linkage could be out of adjustment or it might be the torque converter not engaging the lock-up, which sometimes feels like a 5th gear change. If none of these it could be the computer not getting a signal to shift into overdrive or transmission troubles.
crashburnoveride
07-10-2015 06:39 AM
Jnkml
07-06-2015 01:20 PM
