93 2wd springs
93 2wd springs
I just picked up a 93 2wd yota. engine and transmission are great, all is great except the springs. Don't know what was done to it, but one side has 3 leafs and one has 4 and a axle wrap helper. I would like to replace with new or good used stock springs, but have no idea what stock was.... Any help on source for springs and specs?
3 leaf springs are found on the 2wd trucks, the 4 leaf springs are on the 4wd drive trucks. The springs are interchangeable just have to swap around the center spring pin. On the 2wd it points up and the 4wd it points down. This is due to 2wd springs mount on the under side of the axle and 4wd springs mount on top of the axle.
I suspect shipping would be killer, atleast with the companies I normally use. Pretty sure it would be counted as an oversized box, and probably have to ship each spring separately. I could try to measure up one and get an idea since shipping distance isn't bad, so it might be reasonable. Pretty sure all of the 2wd ones I have are still on the trucks so I'm not sure what the weight would be. I'd guess something like 40lbs each? I'm not the best at guessing weights lol.
