93 2wd 5spd 22re ran out of gas and now it doesn't start
Need help! I ran out of gas in my 22re.....now it won't start. I added a couple gallons of gas. I put a jumper wire in b+ to fp on the diagnostic panel. Fp comes on....? Also, when I release the key from the start position I hear a double click sound on the passenger side of the truck? ECM? Relay? Please help! Thanks, Jeremy!
Since you should have enough gas
It is quite possible if there was lots of rust in the bottom of the tank it coated the sock on the fuel pump not allowing fuel to be pumped.
If the pump was real old it might have died .
Your most likely hearing the Circuit Opening Relay dropping out
