92 Transmission Mount (Sheared bolts??)
Old 01-24-2013, 02:17 PM
shawnphoto's Avatar
Hey everyone, recently long traveled my truck and took it to pismo, came back and had a bit of clutch chatter it seemed like. Upon looking around, i found this: Looks like two bolts got sheared apart, am i correct or are there only supposed to be two there? That is the bottom of the transmission mount, where it mounts to the crossmember. Thanks!!
Old 01-24-2013, 02:53 PM
Co_94_PU's Avatar
You're correct there should be four. They look pretty weathered like they've been missing a long time however. I also don't see any sign that the transmission has moved/shifted, eg no clean spots on the mount. Good catch but maybe not related to your clutch noise.
Old 01-24-2013, 03:13 PM
HighLux's Avatar
Stop dumping the clutch man its a truck.....lol.
Someone may have broke them off...or..stop dumping the clutch.
Old 01-24-2013, 09:16 PM
wyoming9's Avatar
Red face
Looks like someone snapped them off a while ago.
Nothing fresh rubbed off on the mount.:jessica:
Old 01-24-2013, 10:17 PM
niall's Avatar
Yea, I'm going to say that's not the cause of you're new clutch noise. Those were likely sheared the last time the trans was pulled from the truck.
oldirtydirt
02-23-2020 09:30 AM
mskalmus
05-28-2017 07:51 AM
whereAreMyPants
07-22-2015 03:32 AM
HaydenConQueso
07-12-2015 05:22 PM
jon.r
07-11-2015 03:34 PM
Quick Reply: 92 Transmission Mount (Sheared bolts??)
