92 pickup timing issue
finished doing a head gasket job on 92 pickup. put it all back together fire it up and go to set the timing with the light rotate the distributor to as far as it goes and it wont go past 15 degrees before tdc and it idles around 1000. thought maybe i was a tooth out... rotated the distributor one tooth and i can get it to 10 degrees even 0 but the truck runs like crap.what can i be missing.
Staff
It is easy to get a tooth off as you mentioned. Double check that. I install the distributor at the 11 o'clock position and it will rotate to the 12 o'clock. If all of that is correct, make sure all hoses are connected properly and no air leaks.
Try these video in the links for setting timing.>>>> https://www.yotatech.com/forums/f199...l#post51893036
FS[PacNorWest]: 1988 Toyota Pickup 4x4 Long Travel - Seattle, WA - $6500
96taco4x4
02-06-2020 05:16 PM
4Nmissile
11-14-2016 08:54 AM
mdwreckdiver
08-15-2016 02:40 PM
Mr.Chubbles
08-13-2016 11:49 AM
