90 3.0 motor direct swap into 93?
Old 11-04-2015, 10:49 PM
Edionne13's Avatar
Blew my headgasket back in February. A guy is offering me a 90 3.0 fully rebuilt etc. Question is there anything on the 90 3.0 like connection types or wires changed on the 3.0 that would differ from 93 3.0
Old 11-04-2015, 11:42 PM
wyoming9's Avatar
Red face
Most likely the computers will be different.
Any swap you run into wiring differences
Without sitting down doing this swap with both year EWD`s in your hands
If you install your engine harness with your ECU/ECM you should be good to go.
Meaning your putting just the( new to you) long block in your truck all the electrical and electronics is from your truck.
that should make things easier so your not repining connectors
Old 11-05-2015, 08:48 AM
Edionne13's Avatar
Exactly just putting the new to me long block in my pickup and using everything from my truck. Just needed clarification thankt you.
Old 11-06-2015, 09:12 AM
RJR
RJR's Avatar
Just to clarify, I think that also means using your existing injectors, not the ones from the replacement engine.
Old 11-06-2015, 12:34 PM
wyoming9's Avatar
Red face
The only thing being used with the (new to you) engine is mechanical.
Every thing else comes from your truck
If your replacing parts buy them for your truck.
Cab4you26
03-16-2016 01:11 PM
Obmi
11-06-2015 11:26 AM
towotaguy
11-05-2015 08:05 PM
Rickstwowheels
11-05-2015 04:27 AM
Edionne13
11-04-2015 05:20 PM
Quick Reply: 90 3.0 motor direct swap into 93?
