88 toyota pickup chassis electrical. grounds
Can anyone tell me the exact locations of all the electrical chassis grounds both under the hood and in the cab on a 88tough toyota pickup?
Don't know about the cab grounds but I do know about the engine grounds.
1. Battery (-) to fender.
2. Main wiring harness to lower intake bolt
3. Back of the head (where the lifting hook is) to the firewall.
4. Battery wiring to the front of the block.
This all assumes that you have a 22RE.
You should also provide what you have (engine, trim level etc.) whenever you ask a question. It helps so much because I am not a mind reader.
thanks
it"s a 22re. i saw a post on all the engine chassis grounds but just wanted to confirm those. i found one in the cab ( left side behind instrument panel) and wanted some info on any others. thanks to all for the help.
6th Gear
19
12-10-2019 07:31 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
