'88 Pickup CSI Switch
Old 04-25-2017, 10:05 AM
Cryogen's Avatar
Hey all, hoping someone can help me out here.
I have a 1988 Toyota Pickup w/3VZ that needs the Cold Start Injector Switch replaced. OEM Part # 89462-20010. That part has been discontinued and I have had no luck sourcing an aftermarket one.
Did a little research and found 89462-20050 and 89462-20040. The 20050 is for a 22R from an old TSB, but the connector looks the same as the original part. The 20040 is for a later model, but the connector is more rounded at the corners compared to the original that is very squared off.
Has anyone had any luck either installing the 20050 switch? Or even installing the 20040 switch with a pigtail with the correct connector? Worse case, I can just wire up a switch to the dashboard and bypass the CSI Switch, but I would prefer not to do that.
Old 04-25-2017, 12:22 PM
snobdds's Avatar
Call Jim at Jimgotparts.com and he will get you one. I have yet to find something he can't supply.
