88 pickup with 22er and efi wont start
hi I recently picked up an 88 pickup with a 22re with EFI it broke done on my buddy stalled out and now wont start iv seen some posts with the same issue but haven't been able to figure out what's wrong with mine I smell fuel and see spark but all it dose is crank but wont fire I cleaned off the throttle position sensor connection and got a pop bot still wont start any help would be greatly appreciated.
How about some history.
How long has this been running good??
Mileage ??
Just what you have done so far in the way of maintenance ??
Just how are you testing for spark??
Just because you smell fuel does not mean it is where it should be.
Just under what conditions did it quit on your buddy??
Mileage ??
Pull the throttle body to air cleaner tube thingy and spray a little ether in the tb. A little. If it tries to run it is fuel related. Is it throwing a cel. Pull the codes. Check the Fuses for EFI, and Fuel pump. Check fuel pressure.
I just got the truck from a buddy its been running good for years its wasn't his daily driver it has 195k miles on it haven't done much pulled the air intake off check some of the sensors pulled the spark plug wires and checked for spark. my buddy was driving it and he says it shuddered and stalled out on him.
Yes, you do.
http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf
(the SST can be replaced with a paperclip)
Feel free to look around this site a bit first. You'll learn a lot (like how to read codes) just from looking at various question/responses.
kctopher
08-07-2002 01:09 PM
