87 runner sat for 3 years - should I replace all the bushings?
Old 03-31-2010, 06:17 PM
mink's Avatar
Question 87 runner sat for 3 years - should I replace all the bushings?
I am re-invigoratiing an 87 runner that has been sitting for about 3 years. I have replaced th ECU and igniter, and this puppy is running now!
I obviously have a number of items to work on. A friend mentioned that I may want to look at replacing all the bushings, as a truck sitting for that long may have cracks in the existing set.
Performance Accessories has a set to replace the bushings for ~$88. Is this something I should be looking at doing? What is the amount of time I am going to spend replacing the bushings?
Here is the link to the Performance Accessories bushing set
Old 03-31-2010, 06:19 PM
Kiroshu's Avatar
First you get on your back and check them... toyotas are usually good about chassis parts lasting a long time.
Old 03-31-2010, 06:20 PM
Bridger5228's Avatar
You can if you really want to, but that is highly un-necessary.... Your friend is making stuff up, Your bushings may be worn (i.e. spongy), but sitting around for 3 years would not have hurt them...
Old 03-31-2010, 07:17 PM
Kiroshu's Avatar
If its been sitting for that long just change and or add fluids gas tune-up maybe and drive.
Old 04-01-2010, 12:00 PM
mink's Avatar
Thanks for the feedback everyone. I am going to take a close look at the bushings in the suspension and body and make a better educated decision.
Old 04-01-2010, 02:43 PM
betelnut's Avatar
Yeah, just look at them and see if they're cracked. If they need replacing, it's because the truck's an '87 model, not because it's been sitting for 3 years.
Old 04-01-2010, 08:06 PM
az4x4runner's Avatar
Agreed. I would expect them to be in better shape sitting for 3 years than taking a beating every day for 3 years.
Old 04-01-2010, 08:21 PM
pruney81's Avatar
The bushings should be fine. The 4WD and front end components are really stout on these trucks. I'd check the front brake calipers to see if they sticking after sitting that long though. Then, change out all the fluids and drive it for a while and see what else crops up, if anything.
Old 04-01-2010, 09:30 PM
Jay351's Avatar
Put gas in and drive
Don't touch the bushings unless they are cracked and have play
truckmike26
10-26-2015 05:10 PM
Niameyrider
06-25-2015 05:50 AM
infinityisfive
06-16-2015 06:51 PM
Luke
06-10-2002 10:07 AM
Quick Reply: 87 runner sat for 3 years - should I replace all the bushings?
