87 4x4 truck 22r Water pump pulley
Old 06-13-2010, 07:43 AM
Phate's Avatar
Unhappy 87 4x4 truck 22r Water pump pulley
I put a new water pump on my 22r and the pulley seems to hit the bolts on the water pump, as far as i can tell the pulley is not bent, could i have the wrong bolts in the wrong locations? or is there supposed to be a spacer of some type between the water pump snout and the pulley?
Old 06-13-2010, 08:37 AM
cws9685's Avatar
check your old pump to see if the shaft is longer could be a defect or one of the bolts didnt screw all the way in theres no spacers
Old 06-14-2010, 11:15 AM
FastLane1000's Avatar
Could the pulley be on backwards?
Old 06-14-2010, 11:34 AM
xxxtreme22r's Avatar
without seeing a photo, that would be my guess as well.
Old 06-14-2010, 12:29 PM
swampfox's Avatar
check the plate that the pulley goes over, the one with the studs ,to see if it is on straight. i had a water pump on a chevy that the plate was pressed on at an angle. the pulley would hit the housing of the pump on one side when it rotated.
Old 06-14-2010, 07:22 PM
Phate's Avatar
nothing on backwards, the plate with the studs was pressed too far on to the pump it was nearly touching the pump housing. of course the second time i put the pump on i sheered a bolt so now i get to have that fun
voiddweller
19
05-02-2016 09:10 PM
Ichneumon
09-27-2015 04:21 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
paxanders
06-21-2015 06:29 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: 87 4x4 truck 22r Water pump pulley
