86 toyota 4x4 sr5 turbo truck bad turbo
Old 07-09-2014, 04:24 PM
tylerborda2's Avatar
I have a 86 toyota turbo pickup that I bought recently that the turbo exhaust housing is cracked in. I found a new housing for it but I was wondering if I could upgrade the turbo so it is better than stock. I was thinking the ct26 turbo or a t3. But I do not know what is required to do this swap. I can pickup a turbo kit on ebay for 500 bucks but that is pretty much my spending cap. Any help and ideas would be great.
Old 07-09-2014, 08:10 PM
Fossilized
Staff
dropzone's Avatar
we have a ton of members with some knowledge on turbos but you might check out this forum as another source
http://www.22rte-trucks.com/simplemachinesforum/
Old 07-09-2014, 08:22 PM
InToxicOne's Avatar
If youre looking for an upgrade to the old CT20 you will most likely spend a bit of cash. The best for your buck is probably going for the CT26 because most of what you need is tools and some know-how. With the T3 youll need a whole stack of adapters different hoses etc etc. With the CT26 there are quite a few build threads for it. Trust me I run a GT28RS and my turbo not including the kit to adapt it was 1300. You can get a cheaper kit but what quality turbo will you get? If you get a CT26 you can find plenty second hand at a junk yard and just rebuild them or online for fairly cheap. Im not aware of any adapter kits for the CT26 though.
Old 08-05-2014, 04:31 PM
Munkymag's Avatar
Wink Doing the same thing!
i own a 87 4runner turbo with the same crack on the exhaust side of the turbo. I was looking up ct26 swaps on 22re. Check that link out.
https://www.yotatech.com/forums/f116...o-swap-277632/
Planning on getting this done soon. After i replace my fuel pump that went out on me. Its not too hard too get it going on a ct26.
Alex Bessinger
06-28-2015 10:05 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
dirtrider0129
10
06-24-2015 12:24 PM
Yoda
7
06-22-2002 07:14 AM
Quick Reply: 86 toyota 4x4 sr5 turbo truck bad turbo
